Page 22 of 27
FirstFirst ... 12 20 21 22 23 24 ... LastLast
Results 631 to 660 of 790
  1. Originally Posted by gustawa21 View Post
    Originally Posted by AdemA View Post
    @FoxRefire
    I've just add add the MPD URL and change the popup.html style:
    [Attachment 82269 - Click to enlarge]
    But I have now the issue that I am no longer able make selections on:
    - License URL Details
    - PSSH Details
    Here is my updated wvg: https://files.videohelp.com/u/305244/wvg-my.rar
    Can my take a look on it
    I did it this way, check it out, maybe you can fix it yourself
    For Clearkey encrypted streams (not going through the popup), how do I get this to log the MPD file URL to the console?
  2. Originally Posted by gustawa21 View Post
    @FoxRefire
    wonderful, nice work. thanks for share
    Oct 2023
    Afghanistan
    That's an interesting take on it. I had to modify the mpd code to suit a couple of my services, as this picked up the wrong url's, but good job. I like it.
  4. Does anyone know why updating the extension doesn't work? I give it and I get error 404
    https://github.com/FoxRefire/wvg/archive/a1297aa-cdm-project.zip
    Mar 2024
    Poland
    [Attachment 82848 - Click to enlarge]
    a discord user showed off a working add-on that looks like this
  6. Originally Posted by grzech67 View Post
    invite to DC please
  7. he can't share. it's private release
  8. hello, is it possible to run the N_m3u8DL-RE program in the textarea in javascript? how?
    [Attachment 82898 - Click to enlarge]
  9. Originally Posted by sesamap159 View Post
    where did you get that program? Please.
    If you prefer, tell me privately Thanks
  10. Good evening.
    I'm trying to follow these instructions:
    https://github.com/FoxRefire/wvg/wiki
    I couldn't download keydive.py because the link (https://github.com/hyugogirubato/KeyDive/pulls?q=is%3Apr+is%3Aopen+sort%3Aupdated-desc) doesn't work.
    In a Python forum I was advised to use keydive with:
    pip install keydive
    to install.
    I tried everything in a virtual environment under Ubuntu 22.04:
    python3 -m venv Environment
    source Environment/bin/activate
    pip install keydive
    Version: 2.1.0.
    I created and started an AVD in Android Studio. Then I wanted to
    keydive -aw
    start. I get a long list of error messages:
    (Environment) heiko@Worf:~/test$
    (Environment) heiko@Worf:~/test$ keydive -aw
    2024-10-22 20:09:17 [I] KeyDive: Version: 2.1.0
    2024-10-22 20:09:17 [I] Core: Device: Android Emulator 5554 (emulator-5554)
    2024-10-22 20:09:17 [I] Core: SDK API: 33
    2024-10-22 20:09:17 [I] Core: ABI CPU: x86_64
    2024-10-22 20:09:17 [I] Core: Script loaded successfully
    2024-10-22 20:09:17 [I] KeyDive: Watcher delay: 1s
    2024-10-22 20:09:17 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:17 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:18 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:18 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:19 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:20 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:20 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:21 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:21 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:22 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:22 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:23 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:23 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:24 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:24 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:25 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:26 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:26 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:27 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:27 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:28 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:28 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:29 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:29 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:30 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:30 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:31 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:32 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:32 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:33 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:33 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:34 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:34 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:35 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:35 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:36 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:36 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:37 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:38 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:38 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:39 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:39 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:40 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:40 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:41 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:41 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:42 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:42 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:44 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:44 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:45 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:45 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:46 [W] Core: Library not found: libwvdrmengine.so
    2024-10-22 20:09:46 [W] KeyDive: Widevine library not found, searching...
    2024-10-22 20:09:47 [W] Core: Library not found: libwvdrmengine.so
    Can't I start KeyDive in a virtual environment?
    What do I have to do?
    Thank you.
    Best regards
    Heiko
    PS: Sorry for my Google English.
  11. Good evening.
    Can anyone help me here?
    How do you do it with Guesser?
    Best regards
    Heiko
  12. @Data2006
    1. Download Extension from release page
    2. Extract it and paste your CDM in extension folder.
    3. Load the extension in chrome.
    That's it.
  13. Can't follow you right now. Which extension and where from?
    Best regards
    Heiko
  14. Originally Posted by sesamap159 View Post
    Is this extension public? If so link? Thanks.
  15. @Spectrumhsm
    not public. private. and owner can't share
    @Data2006
    read better the post above, and maybe use google translator. DonSeenu says: 1. Download Extension from release page
    so go to the first page of this thread and the link is in the second line in large red characters https://github.com/FoxRefire/wvg/tree/next
  16. Hello everyone, I found a way to download the video with batch or from the flask server in python but I will not share the program publicly.
    [Attachment 83068 - Click to enlarge]
  17. Originally Posted by lomero View Post
    @Spectrumhsm
    @Data2006
    I am following these instructions. So I downloaded the wvg and unpacked it.
    But the link to keydive.py was empty.
    Best regards
    Heiko
  18. what do you need keydive.py for? the Foxrefire guesser need only a cdm, 2 file (client_id and private_key) or 1 only (device.wvd)
    if you need keydive.py to dump cdm from your phone, you can try with a generic cdm ready to use (thanks to Karoolus)
    here: https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21
  19. If I don't need keydive.py, why is it in the manual?
    The manual should then be revised. Thanks.
    Best regards
    Heiko
  20. the manual refer to keydive.py for dump cdm from your phone, but you can use any cdm
  21. Good evening.
    I downloaded a ZIP file with many WVD files from the link mentioned and then unpacked it.
    Selected a WVD file and copied it into the extension folder wvg.
    Then I wanted to install the extension in Firefox. Then a warning appeared (see attachment).
    [Attachment 83071 - Click to enlarge]
    What do I have to do now?
    Best regards
    Heiko
  22. manifest.json:
        "manifest_version": 2,
        "name": "Widevine L3 Decrypter",
        "version": "240731.1",
        "version_name": "a1297aa",
        "icons": {
            "128": "icon.png"
        "permissions": [
            "webRequest",
            "webRequestBlocking",
            "<all_urls>",
            "activeTab",
            "storage",
            "tabs",
            "contextMenus"
        "background": {
            "scripts": ["background.js"],
            "persistent": true
        "content_scripts": [
                "run_at":"document_start",
                "matches":["<all_urls>"],
                "js": ["content.js"],
                "all_frames": true
        "browser_action": {
            "default_title": "Widevine Decrypter"
        "web_accessible_resources": ["inject.js"],
        "content_security_policy": "script-src 'self' 'unsafe-eval'; object-src 'self'"
  23. Widevine L3 Guessor 2024:
    No CDM key pair found!
     https://github.com/FoxRefire/wvg/wiki/Getting-started#2-put-cdm-key-pair-files
  24. on wvg folder put cdm in 2 files device_client_id_blob and device_private_key
    and guesser work with FF but if you have issue, try with chromium based browser like Brave
  25. Good morning.
    Great, it worked now. Also with Firefox.
    How can I set up the extension permanently now?
    Do I have to do this:
    1. Get your Mozilla Developer account
    Best regards
    Heiko
  26. no, you don't have to do anything
  27. OK. Thanks, but how else do I make the extension permanent?
    I have no idea.
